Old 10-22-2009, 02:45 AM   #1
Question tub drain off by 1/2", worth busting concrete?
We're installing a new acrylic tub as a replacement for an old fiberglass tub that had developed a crack. The new tub is deeper, so we knew we were going to have to adjust the height of the overflow pipe. However, during our first test fit of the tub we discovered the bottom drain is misaligned by half an inch:
The drain/overflow assembly is set in our concrete slab (single-story home) as you can see here with the tub gone:
My research so far is pointing in the direction of busting up the concrete and replacing the drain/overflow assembly with one of those off-the-shelf kits. I wanted to check before proceeding down that road, though:
  • is there an easier way to manage some kind of offset drain fitting since it's so close?
  • how confident can i be that i can rotary-hammer my way into the concrete and arrive at a clean attachment point for the new drain kit?
Any & all tips appreciated!
The Z's
tub-drain-off-1-2-worth-busting-concrete-dscn0517.jpg   tub-drain-off-1-2-worth-busting-concrete-dscn0523.jpg
thezs is offline   Reply With Quote
Old 10-22-2009, 04:09 AM   #2
Send a message via ICQ to grillman39
Default may help
I had a new acrylic kitchen sink that would not go in to a counter top just right because of the back splash so I took my dremel tool and trimmed the acrylic off to make it work it looks good you may be able to trim some off the tub or the studs to make it go in but make sure that if to trim or plain the studs that you trim off what you will need for what ever you are going to put on the wall
hope this will help you some way some my think I am nuts
I am some
times
good luck
grillman39
grillman39 is offline   Reply With Quote
Old 10-22-2009, 10:40 AM   #3
If I were off by just 1/32-1/16th" maybe I could use a dremel on the tub to account for it. But 1/2" is way too much.
Adding breathing room at the studs is an interesting idea, but since we bought shower walls that match this tub that will go in next, I'm worried we'll be introducing an error factor there just to get the drain to line up right. As is, aside from the drain, the tub fits perfectly in the alcove space basically flush with all the studs.
I think I'm really looking for ideas in the space of what I can do with the drain plumbing specifically.
Thanks though!
Old 10-22-2009, 09:29 PM   #4
Any other ideas?
Old 10-22-2009, 09:38 PM   #5
I'd bust it up; it likely (famous last words) isn't too thick. May take an hour or so but at least it will make everything else easier.
bob22 is offline   Reply With Quote
Old 10-22-2009, 10:02 PM   #6
Master Plumber/Mechanical
Bust it out and leave it out.
Reconect with a new tub drain and install tub
You will thank yourself when you have the new tub installed and you need to make a repair to the drain. Think about busting concrete out with that new tub installed through and access hole or better yet tearing out a new tub
I always leave the cut out open unless it is for a toilet
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 10-28-2009, 01:34 AM   #7
plumber 101 is right bust it out and keep it open I have a older home built 1978 not that old to me but any way he is right I had to work on my drain and when the home was built they kept the drain open they filled it up with sand at some point the wall was cut behind the tub to look for termites and they put a vent over the hole so thank God all I had to do was open the vent and fix the drain I call a plumber friend and asked him was the open hole in the slab okay he told me that it was okay
More On This Topic
Now we're going to be talking about the material you will need to make your concrete sphere. We are going to start with the concrete. What we have here is a bag of premixed concrete, it's an 80 pound bag but also they come in a 60 pound bag, you could... Read More »
Hi! I'm Jennifer Cail and on behalf of Expert Village, I'm going to show you how to make a green bean casserole as part of your delicious Thanksgiving day dinner. Now that we have our canned green beans drained, or frozen or fresh green beans cooked, we... Read More »
Hi! I'm Mark Sullivan for Expert Village and today I am going to show you how to set concrete paver's. So we have our shovel, we have our concrete paver's. We have our fire pit and we have raked away the area and we are leveling it with our shovel. We... Read More »
Most people love the luxury of owning their own spa or hot tub, but like swimming pools, these soaking spots require regular maintenance to keep them clean and sanitary. No one wants to get ready for a long soak and remove the cover to find discolored or... Read More »
Some other items that are important to have in a kit is like bandages like you could use for making splints or slings. If you have accidents and you sort of, you know, fell down and you want to keep the limb in place so they don't cause any more problems... Read More »
New basemet shower drain advice (pics) civil Plumbing 0 10-11-2009 12:55 PM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 10:21 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 09:10 PM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 05:15 AM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-04-2005 12:27 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
