Tub Drain Location - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-24-2010, 11:45 AM   #1
Rewards Points: 79
Tub Drain Location
The tub I would like to install has the drain location 1.5" farther from the wall or near wear it is shown positioned in the first picture. I can access the drain from underneath but there's not much pipe to work with before it enters the wall cavity with the supply lines and joists there also.
Any suggestions on how to relocate the drain or am I able to install the overflow pipe at a slight downward angle angle to avoid having to move it?
RalphPeters is offline   Reply With Quote
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
L/R Drain bath/shower over center drain location in floor? tigerbalm2424 Plumbing 2 12-04-2007 01:26 PM
Water and Drain Line Location Material Tester Plumbing 1 11-27-2007 07:40 PM
Bathtub drain location kendallk Plumbing 3 11-11-2007 11:02 AM
Drain location off by 1/4" jross Plumbing 24 03-30-2007 06:39 PM
