Old 06-08-2007, 05:47 PM   #1
Tub Drain Install - What's The Trick?
Here's the deal - installing a new one-piece fiberglass tub in a new bathroom and am stumped as to why the drain keeps leaking.
I set the tub into a bed of plaster of paris for bottom support. That step went fine. Also have my ledgers for the sides too. No problem there.
Got underneath the floor to dry-fit the drain /overflow pipe system - that step also went well.
Applied a bead of caulk/sealant to the donut gaskets on both the overflow and the drain basket after Teflon taping the threads and with my wife holding them in place - I screwed the drain basket into the receiver. Also sillycone on the underside of the drain flange too. No problem with the install - made sure the gasket didn't shift to one side or such.
Glued up the rest of the ABS fittings and glued into the P-trap.
Go to water test and GUESS WHAT - the drain gasket leaks. Tried tightening - no good. Took the basket out and rewrapped with fresh tape - no good. Tried it without any sillycone - no good. Tried it sillycone again - no good.
So a callout to the Plumbers in the eworld - what is the supersecrettellnobody trick to getting the donut gasket to stop leaking?
I'm thinking JBWeld
Thanks,
Rick
Ricky D is offline   Reply With Quote
Old 06-08-2007, 10:05 PM   #2
Good old-fashioned plumber's putty on the drain flange. Skip the silicone and teflon.
Ishmael is offline   Reply With Quote
Old 06-09-2007, 07:22 AM   #3
Plumbers putty will turn a fiberglass tub yellow.
Tmb9862 is offline   Reply With Quote
Shower drain gasket install tricks dbrew Plumbing 6 03-10-2010 10:20 PM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 04:15 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 12:13 AM
