Tub Drain Gasket - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-22-2012, 07:04 PM   #1
Tub Drain Gasket
I've been doing battle with an old cast iron tub with brass fittings, trying to replace the drain trim (not the entire drain assembly, just the trim). After reading some other posts and trying every other option, I finally just had to cut the old drain piece out. I'm now ready to put the new one in.
However, I noticed that there was no gasket between the tub and the drain shoe. There was a gasket on the overflow, which I've replaced, but none under the tub. I bought a new one that is 1/8" thick (the thinnest at Home Depot), but this is too thick. Putting it in place puts the shoe pipe at an odd angle. I think I would end up with a leak where the shoe meets the rest of the assembly if I kept the gasket in place. I tried looking online for thinner gaskets, but didn't really find anything. Can I use something else in place of the gasket between the tub and drain shoe? I'll be using plumbers putty under the new trim piece (between the trim and the top of the tub). Could I use plumbers putty (or caulk) between the shoe and the tub to create a seal there? What are my best options at this point?
Thanks!
DCcondo is offline   Reply With Quote
Old 08-22-2012, 07:17 PM   #2
Rewards Points: 582
hey kari...check to see if old gasket is stuck on bottom of tub....really should have one...and would like to see you use the gasket...it should work....how about trying it 1st...before you use caulking...ben
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (08-22-2012)
Old 08-22-2012, 07:38 PM   #3
Yeah, I've checked and double checked. But, there's none there. I have good access underneath, and the cast iron of the tub just comes down and meets directly with the shoe. It's like they just didn't have space for a gasket.
I'd like to have one, of course. But, unless I can find one thinner than 1/8", I may have to move to an alternative option (assuming there is a good alternative).
Also, a second question regarding the new drain. The current drain assembly and shoe are brass. The old drain was brass as well, but the new one comes with a plastic bushing that is necessary for the drain piece to fit properly. Are there any thread seal issues I need to be worried about in attaching the new plastic piece to the old brass?
Old 08-22-2012, 07:57 PM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
How about just installing a new waste/overflow assembly on the tub and making it all fit right
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
New shower drain installed, but gasket not sealing dryvlyne Plumbing 5 10-23-2011 09:29 PM
Shower drain gasket install tricks dbrew Plumbing 6 03-10-2010 09:20 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
