Tub Drain Clogged... Draino Does Not Work! - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-07-2012, 09:32 AM   #1
tub drain clogged... draino does not work!
I can't fit the snake down the drain so I tried draino, vinegar &, baking soda, no luck :-(
Any suggestions?
brianeitz is offline   Reply With Quote
Old 09-07-2012, 09:58 AM   #2
the Musigician
DangerMouse's Avatar
A DIFFERENT way to clear a clogged drain!
this ^ may work, or you could try the plastic barbed strip?
DM
Old 09-07-2012, 10:12 AM   #3
were you running the snake down the overflow?
how old is the house?
The Following User Says Thank You to DannyT For This Useful Post:
brianeitz (09-09-2012)
Old 09-07-2012, 10:16 AM   #4
draino is a very caustic chemical and some of it may be mixed in with your standing water.
make sure to wear goggles at all times to protect your eyes.
allthumbsdiy is offline   Reply With Quote
Old 09-09-2012, 11:15 PM   #5
My house is only 4 yrs old. I can't loosen the drain plug even with a screw driver
Old 09-10-2012, 04:38 AM   #6
DIY staff
Rewards Points: 7,174
Post a picture of your drain and the over flow cover---someone will help you figure out how to remove the drain cove and pop up assembly or plunger assembly so you and get that cleaned out---
Old 09-10-2012, 07:16 AM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 996
hope it wasn't crystal drain O.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
A DIFFERENT way to clear a clogged drain! DangerMouse How To Guides 36 05-11-2015 05:00 PM
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 10:53 PM
Secondary Drain (Relief Drain) Clogged Zeigh Plumbing 4 06-20-2012 09:57 PM
Floor Drain P-Trap clogged, maybe grout? waistdeep Plumbing 1 02-16-2012 03:39 PM
drain clogged larbec HVAC 2 06-21-2011 08:30 PM
