tub drain clogged... draino does not work!
1K views 6 replies 6 participants last post by  Javiles
I can't fit the snake down the drain so I tried draino, vinegar &, baking soda, no luck :-(
Any suggestions?
#6 ·
Post a picture of your drain and the over flow cover---someone will help you figure out how to remove the drain cove and pop up assembly or plunger assembly so you and get that cleaned out---
