Tub Drain Broke - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-23-2009, 03:50 PM   #1
Tub Drain Broke
I have a tub that is leaking. I believe but am not 100% sure that it is the drain leaking from outside perimeter where the plumbers putty is. I bought a new drain and tried to unscrew the old one but the crosstabs broke while unscrewing. What do I do now? How do I get that old drain out?
Thanks,
Mike
mginani is offline   Reply With Quote
Old 01-23-2009, 04:48 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,088
Ayuh,...
A Hacksaw or a Sawzall comes to mind....
Old 01-23-2009, 05:48 PM   #3
Take the hack saw or sawall and cut vertical notch in water ever is left in the try not to cut all the way through, then get hammer and a flathead screwdriver, and use the notch as a brace for the flathead and slowly hammer it to get the piece to unthread, but be gentle.
zosoplumber is offline   Reply With Quote
Broke the Tub Drain Crosspiece, Now What? MrBill_DIY Plumbing 13 05-02-2012 09:28 PM
Condensor drain Captflx HVAC 6 08-17-2008 10:19 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
Help! I can't remove a bathtub drain after I broke the crossbars with a wrench andreajohanson Plumbing 18 04-24-2008 11:47 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
