Tub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-06-2008, 07:54 PM   #1
tub drain
the drain that prevents overflow in the tub leaks down thru the ceiling downstairs. it is a one piece tub and shower enclosure. can this problem be fixed or should i just caulk the drain. my wife likes to fill up the tub past the drain. the handle that opens and closes the main drain on the bottom of the tub works fine. thanks tommymas
tommymas is offline   Reply With Quote
Old 01-06-2008, 08:46 PM   #2
Master Plumber
Rewards Points: 150
You can try to tighten the screws on the overflow plate or replace the gasket .
jpplumber is offline   Reply With Quote
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
How to outline the 1 1/2" PVC drain froddan Plumbing 6 07-24-2007 03:15 AM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 03:42 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
