-   -   tub drain (http://www.diychatroom.com/f7/tub-drain-15262/)
tommymas 01-06-2008 07:54 PM
tub drain
the drain that prevents overflow in the tub leaks down thru the ceiling downstairs. it is a one piece tub and shower enclosure. can this problem be fixed or should i just caulk the drain. my wife likes to fill up the tub past the drain. the handle that opens and closes the main drain on the bottom of the tub works fine. thanks tommymas
jpplumber 01-06-2008 08:46 PM
You can try to tighten the screws on the overflow plate or replace the gasket .
