Tub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-09-2012, 12:31 PM   #31
MarginallyQualified
Rewards Points: 2,464
Originally Posted by di di View Post
oh I have a drop ceiling down stairs... That's convenient!
...I see a little leak but can't see where it is coming from.
As it's VERY unlikely that a rubber stopper won't hold the water back...
the escaping water really must be coming past the trim flange of the drain shoe.
Removing the old one is the hard part of the repair.
Old 01-09-2012, 03:42 PM   #32
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Di Di
Well if theres a drop ceiling underv there you might not need a hole in the ceiling to change it out
plummen is offline   Reply With Quote
Old 01-10-2012, 05:05 PM   #33
tub drain
Originally Posted by plummen View Post
sounds like its time for a new waste/overflow,do you have access to backside of wall behind faucet area?
I have checked the assembly and parts all are their, tried new parts still have same problem. What's waste overflow? sounds to complicated. GOING FOR PLAN B. I am going to put in a foot stopper in stead and see if that works forget the lever! I hope I can get the basket out, in this house one never knows if things were put in right .I'll spray the basket with some PB BLASTER To loosen up any sealer I have a plug wrench well see what happens tomorrow. DiDi problem solved!!
di di is offline   Reply With Quote
Old 01-10-2012, 05:14 PM   #34
That is exactly what i'm trying all ready have the parts Thanks. DiDi
Old 01-10-2012, 11:17 PM   #35
tub drain
problem solved no leaks used a foot stopper so easy step on it with your foot it locks step on it again it unlocks no carnage
Thanks to all it was fun DIDI
The Following User Says Thank You to di di For This Useful Post:
plummen (01-10-2012)
Old 01-10-2012, 11:27 PM   #36
fixed it problem solvedDIDI
Old 01-10-2012, 11:33 PM   #37
plummen's Avatar
The Following User Says Thank You to plummen For This Useful Post:
di di (01-11-2012)
Attaching basement bathtub drain to main drain herbie08 Plumbing 0 04-10-2011 04:13 PM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 10:24 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 10:52 PM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 03:42 PM
