Tub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-08-2012, 11:27 PM   #16
tub drain
Originally Posted by plummen View Post
sounds like its time for a new waste/overflow,do you have access to backside of wall behind faucet area?
no I do not have wall access di di Still figuring out how to use this system sorry if i'm all over the place
di di is offline   Reply With Quote
Old 01-08-2012, 11:31 PM   #17
MarginallyQualified
Rewards Points: 2,464
If I'm reading this right:
1) no stopper, rubber, metal, etc. will keep water in the tub... yes?
2) there is no access hatch to the drain and OF assy....
If the leaking continues unabated...
your downstairs neighbor will soon show you where access to your plumbing can be found.
hth
Old 01-08-2012, 11:32 PM   #18
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Is there a room directly behind the wall with faucet,or maybe a closet?
Plumbing is normally on interior walls tp protect from freezing,how about a picture?
plummen is offline   Reply With Quote
Old 01-08-2012, 11:35 PM   #19
plummen's Avatar
hth
now thats funny i dont care who you are!
The Following User Says Thank You to plummen For This Useful Post:
di di (01-08-2012)
Old 01-08-2012, 11:39 PM   #20
tubdrain
no their is room behind the wall but it is all in closed I would have to break into the wall Di Di
Old 01-08-2012, 11:45 PM   #21
plummen's Avatar
As long as theres a room there,thats what I was getting at.
Figure out about where the tub waste/overflow is in relation to that room and cut an access hole in the sheetrock about 12" off the floor,make it around 6" square to start with to see if youre in the right area.
Let us know what you find,a picture once you open wall would be nice
Old 01-08-2012, 11:48 PM   #22
tub drain
ya ya thats funny
Old 01-08-2012, 11:51 PM   #23
plummen's Avatar
I tell everybody it took my first 2 pacemakers to learn to relax,now that im on number 3 i dont try not to worry about small stuff.
Old 01-09-2012, 12:03 AM   #24
tub drain
It's late i'm done for the night .Thanks to all you jokesters tomorrow another day to get in to trouble . Di Di
Old 01-09-2012, 12:07 AM   #25
to morrow another day to get into trouble DiDI
Old 01-09-2012, 12:11 AM   #26
plummen's Avatar
We'll get through this
Old 01-09-2012, 12:38 AM   #27
Plumber
TheEplumber's Avatar
Rewards Points: 348
Can give us a picture of your trip lever assembly? Be nice to make sure its all there before you start punching hole
Old 01-09-2012, 12:40 AM   #28
plummen's Avatar
We wanna see some carnage!
Old 01-09-2012, 01:15 PM   #29
tub drain
I have to charge my camera will do. oh I have a drop ceiling down stairs, I can see under the tub when I went to look I see a little leak but can't see where it is coming from. Di Di
Old 01-09-2012, 01:17 PM   #30
tub drain
Di Di
Attaching basement bathtub drain to main drain herbie08 Plumbing 0 04-10-2011 05:13 PM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 11:24 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
