Old 01-07-2012, 08:28 PM   #1
tub drain
I followed directions for leaking tub drain but had no success:
di di is offline   Reply With Quote
Old 01-07-2012, 08:31 PM   #2
tub drain
And do tell what would thoughs directions be?
What have you tryed?
Old 01-08-2012, 02:14 PM   #3
tub drain
I have taken it in and out several times, I have tried to adjust it,I tried to make sure the connecting hoops had not slipped although that's hard to know. I was going to try a new set up ? Di Di
Old 01-08-2012, 02:40 PM   #4
MarginallyQualified
tub drain
which aspect of the drain assembly is leaking?
The Following User Says Thank You to TarheelTerp For This Useful Post:
oh'mike (01-08-2012)
Old 01-08-2012, 03:43 PM   #5
tub drain
There are no hoops, so I'll guess you mean the tapered plactic seating washers. Is it leaking at the joints or around the drain it's self.
Old 01-08-2012, 07:23 PM   #6
tub drain
The tub will not hold water for a bath. I have taken out the drain stopper out several times and put it back in. DiDi
Old 01-08-2012, 07:39 PM   #7
MarginallyQualified
tub drain
Take a look at this picture.
The water is likely passing *around* the drain flange where the stopper goes.
Want to try to replace that?
Old 01-08-2012, 07:51 PM   #8
call me E
TheEplumber's Avatar
tub drain
Are you referring to the stopper as in your other post? If so, only one post is needed
Old 01-08-2012, 08:39 PM   #9
retired elect/hvac/plumb
plummen's Avatar
tub drain
Try adjusting the bucket/drum on the stopper
plummen is offline   Reply With Quote
Old 01-08-2012, 08:41 PM   #10
Super Moderator
tub drain
I merged the two posts----Without a picture this post is going nowhere----
Old 01-08-2012, 08:45 PM   #11
plummen's Avatar
tub drain
Remove the lever assembly and try running it with just the bucket and rod temporarily to see if it will hold water,if it still doesnt hold water you have bigger issues
Old 01-08-2012, 09:20 PM   #12
tub drain
If the bucket is the stopper at the end of the inside assembly and by assembly I mean the two parts of metal that are linked together with the end stopper that goes down the pipeline. I have had that in and out trying to figure out the proper adjustment. I try what you said . Di Di
Old 01-08-2012, 09:32 PM   #13
plummen's Avatar
tub drain
Yep,thats the piece im talking about.
Old 01-08-2012, 10:52 PM   #14
tub drain
I took off the lever and put the rods and stopper and let sit in the pipe,I know it was hitting bottom . still would not hold water. Di Di
Old 01-08-2012, 11:23 PM   #15
plummen's Avatar
tub drain
sounds like its time for a new waste/overflow,do you have access to backside of wall behind faucet area?
Attaching basement bathtub drain to main drain herbie08 Plumbing 0 04-10-2011 05:13 PM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 11:24 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
Basement Drain + Carpet redwards Plumbing 1 07-21-2006 04:42 PM
