Old 09-19-2012, 02:38 PM   #1
Question
tub diverter spout slip fit type to 3/4" IPS
Hi,
Is there any tub diverter spout on the market with slip-fit type fit to 3/4" IPS?
When I took out my old spout which was the front-end thread, the metal nipple was stuck to the end of the pipe coming out from the wall and I can't remove it.
So I am going to cut the pipe and use a slip-fit type spout, but can't find any in homedepot, lowes, menards, or even plumbing supplies.
Any suggestions are appreciated.
Thanks,
DW
dwjang is offline   Reply With Quote
Old 09-19-2012, 03:24 PM   #2
A "Handy Husband"
rjniles's Avatar
Remove the 3/4" nipple from the wall (it is screwed into a threaded elbow). Get a 3/4 by 1/2 copper male adapter and solder a 6" length of copper into the adapter.
Now wrap with teflon tape and install in the wall. Buy a diverter spout that will slip fit on the 1/2:" copper. You may have to shorten the copper some.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
plummen (09-19-2012)
Old 09-19-2012, 11:29 PM   #3
Master Plumber
Javiles's Avatar
Originally Posted by dwjang View Post
Hi,
Thanks,
DW
The answer to you question is no.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Tags
diverter, spout, tub
having trouble getting a tub spout back on rkFrisco Plumbing 4 09-12-2010 08:18 PM
Can you change from pull type fixture mounted diverter to a spout type? indigojoker Plumbing 7 07-07-2010 09:30 AM
Underground Supply line, 3/4" poly or type K Mr Chips Plumbing 7 03-25-2009 11:59 PM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 11:53 PM
Tub spout diverter problem Chaosdragon13 Plumbing 2 05-28-2008 01:23 PM
