Tub Diverter & Pex Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2011, 08:15 AM   #1
whirly's Avatar
Ok so i have completed my plumbing for my bathroom shower which included various PEX/Sharkbite applications. I have about 3" of PEX coming out of the shower wall for the tub spout. I have installed a Moen Chateau shower faucet. The issue is when i slide the diverter onto the pex ... it isnt secured. The diverter doesnt have a set screw, and caulk alone does not secure it enough. Is there an adapter for the PEX that allows the twist on of the divereter onto the pex ?
I will include pics if necessary...
Thanks !
whirly is offline   Reply With Quote
Old 01-18-2011, 08:29 AM   #2
if it were me, i'd take that pex out and use copper for the tub spout. i've never had any luck using pex in that application
the_man is offline   Reply With Quote
The Following User Says Thank You to the_man For This Useful Post:
whirly (01-18-2011)
Old 01-19-2011, 10:57 AM   #3
whirly's Avatar
Im afraid removing the pex is not an option ...
can anyone suggest something ?
Old 01-19-2011, 12:27 PM   #4
As a plumber, there is not a realistic way to correct this problem without correcting the pipe type, spout stub out. pex has a copper stub out that could be used but it will require a copper coupling to be installed w/ a copper 90. the pex pipe even w/ a stiffner will not work, or for long as it is. gotta open that back wall up and sweat in hard pipe.
Navien Plumber is offline   Reply With Quote
3 way switch with pass through power connection issue ccmbee Electrical 2 09-28-2010 02:38 PM
Shower Diverter questions... dgates12 Plumbing 3 07-29-2010 07:15 PM
gas dryer connection question rvegab00 Plumbing 7 12-07-2009 10:53 AM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
Broken Diverter? Need HELP! URGENT!!! esadiek Plumbing 2 09-07-2008 08:31 PM
