-   -   tub calking (http://www.diychatroom.com/f7/tub-calking-12415/)
danfman 10-15-2007 03:40 PM
tub calking
I need to recaulk around my bath tub. In some of the areas the gap is quite large (1/2-5/8" gap) and this makes it difficult. Does anyone have any helpful suggestions?
Also are there any tricks in general to make the project go nice and smoothe with good results?
send_it_all 10-15-2007 05:31 PM
I'm not even sure I want to know why you have 5/8" gaps around your tub. Home Depot sells a product called backer rod that is a round foam material, sold in a roll, in different diameters. It is designed for that exact purpose, to fill large gaps before caulking. You stuff it in the gap till its lies just below the surface, and caulk over it. It reduces the amount of caulk needed and keeps the caulk from falling through the gap. That's what you need.
send_it_all 10-15-2007 05:33 PM
Also, it would be wise to fill your tub before you caulk around it, That will make the gap reach it's widest point. If you don't the caulk will set, then next time you fill the tub it will pull the caulking apart or at least stretch it.
