Trying To Understand My Well Pump Setup - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-14-2013, 09:56 AM   #1
Trying to understand my well pump setup
Hi all,
I'm trying to get a better understanding of my well water pump. I've attached a photo of it. I know what the water softener is, as I dumped tons of pellets into it monthly My question is what are the two large tanks for? One is off to the left and has a pvc pipe running to it. I can't tell if that tank has another pipe running out of it going elsewhere. And the other large tank is in line with the water softener. I assume it's some type of reserve?
Questions:
1. What are the two tanks for?
2. Do either of these tanks need any sort of maintenance?
3. With what you see in this plumbing, do my outdoors water faucets get softened water or normal well water? (I mean, am I wasting all my softened water on plants?)
Thank you kindly
chamino is offline   Reply With Quote
Old 06-14-2013, 10:21 AM   #2
jproffer's Avatar
Rewards Points: 706
The larger tank on the left is a pressure tank so the pump doesn't have to run every time, and the entire time, you are running water.
Small one on the right...(the rest of this sentence is my best guess )...is part of the water softener??...or a filter....maybe.
There's no way to tell by that picture if the outside water is softened. If your pump is installed like we used to, then it's not...but other people/companies may do it differently.
jproffer is online now   Reply With Quote
Old 06-14-2013, 01:20 PM   #3
joed's Avatar
Rewards Points: 12,002
Look like the one on the right is a filter then a water softener. The one on the left is the pressure tank for the system.
I can't tell from the images where you outside faucets connect into the system. Any pipes before the large square white tank are not softened.
Old 06-14-2013, 05:35 PM   #4
Rewards Points: 258
Some water softeners have a charge tank that is what yours has. Google water softners
redman88 is offline   Reply With Quote
Old 06-14-2013, 11:23 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 990
at least the floors clean around that setup
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 06-17-2013, 02:23 PM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
The shorter "Well Mate" tank on the left is your pressure tank for your well. It stores water under pressure that empties as you use it until the pump kicks on to refill it. The tank to the right is the water softener tank. your well water runs through it and the beads inside "clean" the minerals out of the water. When the water softener recycles, it takes water from the other hopper (where you dump salt pellets) and uses that salt water to flush the minerals off of the beads in the taller tank. They are then ready to cleanse your well water once again. Not much to maintain until something fails. When your water softener reaches a point where it no longer "cleans" the minerals fromm the water, then you may need to replace the "beads". If all of your piping comes off of the water line past the water softener, then yes, you are watering plants with soft water. Normal practice, around here at least, is to plumb a by-pass around the water softener. Doesn't look like you have that set up.
Help with ejector pump biggidybankston Plumbing 3 10-18-2011 02:36 PM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 07:51 PM
Rain Collection System Using Collection Tanks in Multiple Locations Gheuett Landscaping & Lawn Care 10 09-15-2010 09:30 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
