-   -   Trying to understand my well pump setup (http://www.diychatroom.com/f7/trying-understand-my-well-pump-setup-181824/)
chamino 06-14-2013 08:56 AM
1 Attachment(s)
Hi all,
I'm trying to get a better understanding of my well water pump. I've attached a photo of it. I know what the water softener is, as I dumped tons of pellets into it monthly:) My question is what are the two large tanks for? One is off to the left and has a pvc pipe running to it. I can't tell if that tank has another pipe running out of it going elsewhere. And the other large tank is in line with the water softener. I assume it's some type of reserve?
Questions:
1. What are the two tanks for?
2. Do either of these tanks need any sort of maintenance?
3. With what you see in this plumbing, do my outdoors water faucets get softened water or normal well water? (I mean, am I wasting all my softened water on plants?)
Thank you kindly
jproffer 06-14-2013 09:21 AM
The larger tank on the left is a pressure tank so the pump doesn't have to run every time, and the entire time, you are running water.
Small one on the right...(the rest of this sentence is my best guess :) )...is part of the water softener??...or a filter....maybe.
There's no way to tell by that picture if the outside water is softened. If your pump is installed like we used to, then it's not...but other people/companies may do it differently.
joed 06-14-2013 12:20 PM
Look like the one on the right is a filter then a water softener. The one on the left is the pressure tank for the system.
I can't tell from the images where you outside faucets connect into the system. Any pipes before the large square white tank are not softened.
redman88 06-14-2013 04:35 PM
Some water softeners have a charge tank that is what yours has. Google water softners
Javiles 06-14-2013 10:23 PM
at least the floors clean around that setup:thumbsup:
Maintenance 6 06-17-2013 01:23 PM
The shorter "Well Mate" tank on the left is your pressure tank for your well. It stores water under pressure that empties as you use it until the pump kicks on to refill it. The tank to the right is the water softener tank. your well water runs through it and the beads inside "clean" the minerals out of the water. When the water softener recycles, it takes water from the other hopper (where you dump salt pellets) and uses that salt water to flush the minerals off of the beads in the taller tank. They are then ready to cleanse your well water once again. Not much to maintain until something fails. When your water softener reaches a point where it no longer "cleans" the minerals fromm the water, then you may need to replace the "beads". If all of your piping comes off of the water line past the water softener, then yes, you are watering plants with soft water. Normal practice, around here at least, is to plumb a by-pass around the water softener. Doesn't look like you have that set up.
