Trying To Shut Off Water To Install Washer And Dryer - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2010, 08:50 PM   #1
Trying to shut off water to install washer and dryer
My husband is trying to shut off the water to install our washer. But he can't seem to find where it can be. I hope this question isn't too broad. Anyway, we live in a house that is separated into apartments. Where in the basement would this water valve be?
husband&me is offline   Reply With Quote
Old 04-04-2010, 09:00 PM   #2
Learning by Doing
Leah Frances's Avatar
Time to start hunting - look for where the water 'comes into' the house - there should be a shut off valve there. But no promises.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 04-04-2010, 09:16 PM   #3
Rewards Points: 352
Try to shut the valve after the meter first, if that wont shut the water off, shut the valve before the meter. That should shut all the water off. Frequently houses with basements have a pair of boiler valves just above the utility sink they are for the washer
plumberinlaw is offline   Reply With Quote
Old 04-04-2010, 09:22 PM   #4
Thanks for the replies! What's weird is that he was able to shut off the hot water valve and hook up that hose, but the cold water valve just won't turn off. I think he's going try to turn off the water in the entire house. Wish us luck!
Old 04-04-2010, 09:34 PM   #5
Water Treatment
Rewards Points: 900
Some times getting some thing off that has been on for years takes a long cheater bar on the wrench.. just to turn a handle.. or the fitting to remove the hose fitting..
Best of luck ..
Akpsdvan is offline   Reply With Quote
Tags
mixing valve , washer
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 05:29 PM
Relocation of washer and dryer genie Plumbing 2 01-25-2009 02:29 PM
Water leaking in garage everytime we use washer! Please Help shigyrl217 Plumbing 3 12-16-2007 07:03 PM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
