Trying To Run A Camera Down A Sewer Drain... - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2011, 01:04 PM   #1
Trying to run a camera down a sewer drain...
I have a slow drain on my sewer line going out to the road. I have ran a snake with a single blade about 80 feet out. The road is about that far out, give or take 10 feet for the slope and everything. With about 80ft of cable out I hit what seems like to be a wall. I just cannot get any further. The blade comes back clean, no roots or anything. I did check with the city already and they said everything is fine on thier end. I ran a camera down but there is standing water down that far and I cannot see through the poop soup.
Any suggestions on how I can see whats abstructing this? I don't really want to start digging before seeing for sure what the issue is.
Thanks for any input.
TheDudeMan is offline   Reply With Quote
Old 03-24-2011, 10:09 AM   #2
Bump. No suggestions? I have been asking friends and they were thinking an in line water pump. I don't know about that it may be a poop-fest........
Old 03-24-2011, 10:24 PM   #3
Rewards Points: 352
what size cable did you use? can you post a picture of the cutter you used?
plumberinlaw is offline   Reply With Quote
Old 03-24-2011, 10:53 PM   #4
Homerepairguy's Avatar
Rewards Points: 990
Is there a tree near the 80 foot point? Wonder if the "wall" you're hitting is a root?
If you want to see where your underground drain pipe is running (if it's made out of metal) without digging, you can use two brass brazing rods. I found my father's drain pipe about 100 feet from his house using this method.
HRG
Homerepairguy is offline   Reply With Quote
Old 03-24-2011, 11:22 PM   #5
you'll have to get the drain open before you can look at it. i've never heard of any kind of pump to get the water out of the sewer line, plus the farther you go into a blockage the more solids are in it. try a drain king http://www.amazon.com/Water-Products..._syf_dtl_top_3 or pay a drain cleaning company to jet the line at 4000 psi to pop a hole thru the blockage if you really wanna see it. or just dig it up if nothing else, it might be worth it to pay a drain cleaner to give it a shot... we have a lot more experience at running cable than you do (guessing)
the_man is offline   Reply With Quote
How to avoid sewer problems or gain the upper hand in a home purchase LateralConcepts How To Guides 0 02-01-2011 12:10 PM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 08:49 PM
Basement Floor Drain & Sewer Gas 1914 Home Plumbing 4 09-26-2009 04:46 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 08:09 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
