Trying To Remove Tap Cartridge - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-16-2014, 08:18 PM   #1
Rewards Points: 141
Trying to Remove tap Cartridge
This is the cold water side of a kitchen faucet. I've removed the small retaining clip from the cartridge but I don't know what to do next. Do I try to pull out the cartridge or do I undo the 6-sided nut first, then pull out the cartridge? Photo below.
RocketGal is offline   Reply With Quote
Old 03-16-2014, 08:25 PM   #2
Rewards Points: 444
With the supply valve closed of course, turn the 6-sided ( hex ) nut counter clock wise to remove and pull the cartridge out.
Old 03-16-2014, 08:42 PM   #3
Rewards Points: 141
Thanks. Yes, the water is off and I think I will use some Liquid Wrench on the nut. For now it won't budge!
Old 03-16-2014, 08:49 PM   #4
Rewards Points: 12,876
It's best to use a 6 point deep well socket and a ratchet or at least a box end wrench.
An adjustable wrench or open end may just round it of.
A light tap with a hammer on the end of the ratchet or wrench will snap it loose.
oh'mike (03-16-2014)
Old 03-16-2014, 11:12 PM   #5
Rewards Points: 141
I see how those adjustable open ended wrenches don't grip as well as they should. My socket isn't deep enough to grab the nut and clear the top of the cartridge so that won't work. I have a few box end wrenches downstairs and will try tomorrow.
Old 03-16-2014, 11:17 PM   #6
You can do it.
Anytime you trying to remove something like that, be it a lug nut on a tire or a shower stem they may have been on there a long time.
That first sharp blow instead of a steady pull will often break it free.
Old 03-17-2014, 09:32 PM   #7
Rewards Points: 141
The box end wrench and some firm taps with a hammer hasn't worked yet. It's really stubborn but it has to be removed so I can put another one in and use the sink again.
Old 03-17-2014, 10:36 PM   #8
Rewards Points: 444
Sometimes those need the shock treatment to distort the shape momentarily to break the crusty bond. This can sometimes be accomplished by holding an anvil backup on one hex flat and striking the opposite flat with a hammer. Do this on as many flats as you can get to. The back up should be heavy but sometimes someone holding a hammer head firmly against the flat will do.
If I didn't have a 6 point socket or box wrench I'd probably be reaching for my pipe wrench.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
RocketGal (03-17-2014)
how to remove timer box for hallway lights at apartment building mikael6 Electrical 3 01-16-2013 09:31 AM
What is the best way to remove this tiling and how much to remove? wknddiy Tiling, ceramics, marble 6 12-03-2012 10:09 PM
Removing Bathtub Cartridge pvryderz Plumbing 8 10-22-2012 06:32 PM
Remove laminate backsplash georgioltd Remodeling 4 10-17-2012 07:56 AM
remove cartridge from Grohe model 33619 rjgogo Plumbing 1 11-23-2009 08:46 AM
