Trying To Loosen Stem Valve Nut - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-01-2006, 07:49 PM   #1
Trying to loosen stem valve nut
I am attempting a presumably simple task - repairing a leaky faucet. (Of course, nothing is ever easy!) I have a compression type valve causing the drip. I removed the handle and am now trying to remove the valve stem. I am trying to loosen the valve stem nut, but it won't budge. I tried using an adjustable wrench, and then tried a pliers so that I could squeeze a grip on the nut. However, I am trying not to force it because I do not want to strip the nut. Any suggestions?
mjay is offline   Reply With Quote
Old 05-03-2006, 11:14 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
It should unscrew counter-clockwise. Use a larger adjustable wrench or a valve socket and enough leverage to turn it out.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Harden faucet stem removal jrm Plumbing 42 03-20-2016 09:42 AM
ball valve leaking bwall Plumbing 10 12-31-2012 07:25 PM
Toilet valve replacement? steve771 Plumbing 18 07-10-2007 10:50 AM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 02:17 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
