-   -   Trying to loosen stem valve nut (http://www.diychatroom.com/f7/trying-loosen-stem-valve-nut-2398/)
mjay 05-01-2006 07:49 PM
I am attempting a presumably simple task - repairing a leaky faucet. (Of course, nothing is ever easy!) I have a compression type valve causing the drip. I removed the handle and am now trying to remove the valve stem. I am trying to loosen the valve stem nut, but it won't budge. I tried using an adjustable wrench, and then tried a pliers so that I could squeeze a grip on the nut. However, I am trying not to force it because I do not want to strip the nut. Any suggestions?
Mike Swearingen 05-03-2006 11:14 PM
It should unscrew counter-clockwise. Use a larger adjustable wrench or a valve socket and enough leverage to turn it out.
Good luck!
Mike
