Trying To Identify A Cap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-25-2009, 11:46 PM   #1
Question
trying to identify a cap?
Hello I have a question about a fitting and was hoping someone could identify it for me, since trying to look it up has not brought any results.
All I wish to know is what type of caps are those on the top of the bucket because I am hoping to purchase ones of that same type.
~Graham
Chafire is offline   Reply With Quote
Old 11-26-2009, 05:42 AM   #2
Plumber
Hmmm not sure about the answer maybe send an e-mail to http://www.homeplumbingandheating.co.uk good luck!
thefonz22 is offline   Reply With Quote
Old 11-26-2009, 06:26 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,382
Ayuh,... Just a Guess,...
The white fittings look like 3/8" or 1/2" compression fittings for tubing...
The red 1 appears to be 1" pipe thread...
Bondo is online now   Reply With Quote
Old 11-26-2009, 06:35 AM   #4
Wild a-- guess
A receiving tank for condensate and outlets to run plastic hoses to sink or drain. Whatever.
Can't wait to hear from someone who actually knows.
Or a tank to hold chemicals to be pumped into a system like Boiler treatment or swimming pool chlorine.
SULTINI is offline   Reply With Quote
Old 11-26-2009, 08:29 AM   #5
I agree that they look like plasic compression type fittings for adding plastic tubing.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-26-2009, 10:02 AM   #6
Thanks for the replys everyone, I'm going to try to e-mail home plumbing and heating. Also if any of you are wondering what this is it is for a DIY canister filter for an aquarium, just I'm planning on making mine a bit bigger with a 5 gallon bucket and am pulling ideas from others projects. Going to try to rig it so the heater and Co2 reactor both can fit inside the 5 gallon bucket as well as the filtration so I got to make sure its leak proof.
Heres a farther zoomed out photo of the completed canister filter that I'm trying to mimic
Thanks,
~Graham
Old 11-26-2009, 11:22 AM   #7
Although I haven't seen them in white they are compression fitting http://www.siemon.com/uk/e-catalog/E...ssion-fittings You can get them at most electrical supply stores.
hayewe farm is offline   Reply With Quote
Old 02-22-2010, 07:27 AM   #8
Licensed Master Plumber
I suspect you can get them at a RV supply store.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-22-2010, 06:00 PM   #9
they could be one of those plastic fittings like a sharkbite. i think watts makes them and another company i can't think of atm.
plumber Jim is offline   Reply With Quote
Old 02-22-2010, 11:20 PM   #10
Household Handyman
Rewards Points: 1,408
They are not a "shark-bite" type fitting. There is a plastic or rubber sleeve just below the compression nut--or should be. My experience with these is that they are used with "Tygon" type (a semi-hard, opaque colored) plastic tubing. These work the same way copper tubing compression fittings do. We used them for chemical feed lines. tubing sized on one---male pipe threads on the other. IF I were searching for these, I would check the "McMaster-Carr" website. If not there, try a local chemical supply place, or maybe a pool business. David
help identify black hair like jelybu General DIY Discussions 9 09-25-2009 09:27 AM
How can you identify a drill bit or saw blade by looking at it? gomerpyle Building & Construction 6 06-13-2009 07:45 PM
Can someone help me identify my ac unit please :) JamieS HVAC 15 04-30-2009 10:16 AM
Please help identify this ... lilxjohnny General DIY Discussions 3 12-14-2008 08:03 PM
