Troubleshooting Rheem water heater
if the main burner is yellow it is starving for air is the pilot yellow got a model number or pix that dryer lint would of burned off going thru the HWH.if there is an removable cover to view the pilot that should be plenty of air for the pilot and the burner..a little steel wool or sandpaper on the thermal couple rod (that copper tube) from the top of the gas valve into the pilot..just grab it couple of turns.make sure it is tight on the connection into the top of the gas valvefinger tight then easy wrench it....if it is a standard HWH with a flue pipe standing pilot is is ptretty simple...we'll get it don't flip it... change parts... or replace it.when the pilot flame is hitting the copper end of the TC and generates a voltage to tell the Main Gas Valve to open up and heat the water....set the temp dial to 12 O'Clock position.flue should draft with the heater on or off...take a match and light it and hold it up to the vent opening it should pull the flame or smoke right up
