Old 04-20-2009, 08:43 PM   #16
Trouble soldering
Make sure your heating the fitting not the pipe.
Make sure both fitting and pipe are brushed clean.
If you get the pipe and fitting at the same heat you will have problems.
You can wipe off any excess drip before it cools.
smorley is offline   Reply With Quote
Old 04-20-2009, 08:47 PM   #17
Oldie but Newbie
Trouble soldering
Originally Posted by secutanudu View Post
1. I just had it clamped to a 2x4 that was laying off the edge of a table. I just bought a black and decker workmate (wooden vice type thing). Am I better off wrapping the pipe in a towel or something where the vice squeezes it to insulate it?
No, it should be fine as long as the joint your soldering isn't clamped directly in the vise. If the joint is at the end of a few inches of pipe, you should be fine.
LookoutRanch is offline   Reply With Quote
Old 04-20-2009, 10:47 PM   #18
Just call me Andrew
Trouble soldering
Originally Posted by Aggie67 View Post
A lawn sprinkler or fire protection sprinkler?
Sorry - lawn sprinkler.
secutanudu is online now   Reply With Quote
Old 04-21-2009, 03:55 PM   #19
Mechanical Engineer
comp1911's Avatar
Trouble soldering
clean
clean
clean
tinning flux
MAPP gas
comp1911 is offline   Reply With Quote
Soldering? Dont try radioshack 15/30w dual heat soldering iron! rgsgww Off Topic 2 03-14-2009 11:56 PM
Tips for Soldering "up"? moneymgmt Plumbing 10 10-24-2007 08:35 AM
ISO Soldering gear/equipment. Jeekinz Plumbing 1 04-16-2007 02:14 PM
