Trouble Replacing Double Sinks Drains That Are Attached To Each Other - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2012, 10:02 AM   #1
Trouble replacing double sinks drains that are attached to each other
An old double sink in the basement is leaking. The problem is that the threads of the drain flange that the tail peice connects to have disitegrated and that where it is leaking. I don't know how to disconnect the "thing" the drains feed into. Both drains feed into a single iron "thing" that then connects to the tailpiece.
larsoneric is offline   Reply With Quote
Old 05-10-2012, 10:07 AM   #2
Rewards Points: 12,802
Post a picture.
If it's what I think it is, I just split it with a Dremel tool with a cut off blade making sure not to go to deep and cut the threads. Once split a tap with a chisle will open it up and it should just about fall off.
Old 05-10-2012, 06:51 PM   #3
Take a hammer to it till its in pieces you can carry and put a new plastic laundry tray
plumberman134 is offline   Reply With Quote
The Following User Says Thank You to plumberman134 For This Useful Post:
TarheelTerp (05-10-2012)
Replacing single pole light switches with double pole bruce54 Electrical 43 04-15-2012 11:23 AM
Changing A Double Switch to a single pole switch and a dimmer switch loydbrahn Electrical 0 11-09-2011 12:00 AM
Plumbing Double Vanity sinks 36" apart on center kurt2 Plumbing 6 02-03-2011 09:07 PM
replacing single ceiling cylinder light with double ceiling cylinder light in kitchen Travlr234 Electrical 5 06-29-2009 09:14 AM
Argh, double sink drains backing up Skeletor916 Plumbing 9 03-01-2009 09:05 AM
