Old 04-06-2010, 02:32 PM   #1
Just call me Andrew
Trouble removing T&P Valve from water heater
A friend's T&P Valve is leaking, no increase in temp or pressure so he wants to try to replace the valve. Trouble is getting the old one off. Any tricks? There doesn't appear to be a locknut or anything preventing it from turning.
Also - what is the proper type of pipe to hook up to the output of the valve to a drain/bucket? Regular PVC ok or do I need to use CPVC?
Does CPVC use the same primer/glue as regular PVC?
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 04-06-2010, 02:43 PM   #2
A "Handy Husband"
rjniles's Avatar
Get a bigger pipe wrench. They are just threaded in.
I would use copper but CPVC is acceptable in most jurisdictions. PVC is not. There is a special primer and cement for CPVC or use can use the multipurpose stuff.
Coastal South Carolina
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
secutanudu (04-06-2010)
Old 04-07-2010, 05:59 PM   #3
Just by a piece of black pipe threaded and screw it into the TP Valve.
Make sure it goes all the way down to the floor.
COLDIRON is offline   Reply With Quote
Old 04-07-2010, 06:35 PM   #4
Just call me Andrew
The TP valve is on top, so there will have to be an elbow to make it go towards the floor.
Andrew
Seal for a leaking hot water heater safety valve topspinken General Discussion 9 10-14-2009 04:51 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
Water Heater Pressure relief valve problem joedadog Plumbing 5 01-14-2009 02:58 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
