Trouble Removing Old Kitchen Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2011, 05:32 PM   #1
Tried a couple of hours trying to remove the old leaky faucet, removed all water supply lines as well as the spray.
Does not seem to have nuts and bolts holding the base, passed the step that needed an Allen wrench to remove the adapter, but got held up in this step, now only the base is still attached with the counter top, anyone can shed some lights on how can I remove this sucker?
dalishi is offline   Reply With Quote
Old 09-21-2011, 05:40 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There isn't a single large nut down below?
Old 09-21-2011, 05:41 PM   #3
Nope, no nuts under the counter.
I am puzzelled
Old 09-21-2011, 05:42 PM   #4
To answer Bud Cline's question - nope, no nuts underneath
Old 09-21-2011, 05:44 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Hang on. One of the local plumbers here will be along shortly. If there is no nut down there I have no idea what's up.
Old 09-21-2011, 05:54 PM   #6
I removed a clamp underneath the counter, and this is what looks like now underneath.
Old 09-21-2011, 05:57 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I have never in my life seen anything like that. Is the metal piece simply glued to the stone somehow? Is the upper piece loose?
Old 09-21-2011, 05:58 PM   #8
The upper piece feels like is set in stone, no movement after I tried to yank it. Also this old faucet came with the house, I could not get a identification of what brand is, how odd
Old 09-21-2011, 06:02 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Silicone top and bottom maybe.
Old 09-21-2011, 07:10 PM   #10
Still no luck, however found this video on youtube, the host indicates that for some faucets, they need to be removed from above, if no nuts and bolts underneath, but he did not elaborate...
http://youtu.be/HlLF24acHbs
Old 09-21-2011, 07:17 PM   #11
DIY staff
Rewards Points: 7,174
There is a long brass nut on the center tube that is pressing against the steel plate--Remove that nut and the steel plate will come loose and you're done.
Moen provides a deep socket wrench with the faucet to make installing easier.
Any wrench will do.
Old 09-21-2011, 07:36 PM   #12
Rewards Points: 1,558
Hard to tell but the inside looks like a Delta to me but the underside looks like Moen. Have you tried giving it a whack on the side to break it loose from the countertop?
Is there a nut underneath on that center corroded pipe for the sprayer? If so, that needs to be removed.
bob22 is offline   Reply With Quote
Old 09-21-2011, 07:55 PM   #13
DIY staff
Dalishi--Any luck? Take off the bottom nut--that's all there is to it.
Old 09-21-2011, 08:15 PM   #14
worked!! Removed the nuts using a basin wrench, a bit tight but managed to remove, now the sucker is off, time to install the new faucet!! thank you so much!
The Following User Says Thank You to dalishi For This Useful Post:
oh'mike (09-21-2011)
Old 09-22-2011, 05:26 PM   #15
AlbacoreShuffle's Avatar
Good job.
Heres a little tip.
Next time you run into this, bend the cooper lines back and forth and they will snap right off.
That will give you extra room to work on getting the rust ball of a nut off.
AlbacoreShuffle is offline   Reply With Quote
removing very old kitchen faucet. Eric Maurer Plumbing 3 02-13-2011 02:21 PM
Replacing a kitchen faucet Anna123 Plumbing 3 06-09-2010 06:48 PM
Any advice on picking a kitchen faucet? ilyaz Kitchen & Bath Remodeling 2 02-08-2010 07:11 AM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 03:02 PM
Question about a kitchen faucet skwpt Plumbing 10 10-11-2007 07:54 PM
