Old 11-08-2009, 10:33 PM   #1
Question
Trouble removing kitchen faucet
I am trying to remove my kitchen faucet and I can not get the screw out of the center (below where the handle was). I have turned it for 1/2 hr. and it doesn't seem to be going anywhere. Any ideas???
rebeccac is offline   Reply With Quote
Old 11-08-2009, 11:34 PM   #2
post a picture of what faucet you are trying to remove and what it is you are turning.
plumber Jim is offline   Reply With Quote
Old 11-08-2009, 11:50 PM   #3
Picutes are attached.
Old 11-09-2009, 12:00 AM   #4
I don't see any pictures.
Old 11-09-2009, 12:01 AM   #5
Pictures are above. Sorry.
Old 11-09-2009, 12:01 AM   #6
ok, thats a moen it looks like. In order to remove that faucet you need to unbolt it from under the sink.
Old 11-09-2009, 12:08 AM   #7
This link may help. maybe not the exact model but should be similar . Its the install instructions just reverse it.
http://www.moen.com/consumersupport/...1/moen0101.cfm
Old 11-09-2009, 12:20 AM   #8
It is a Moen, but I can't see any bolts under the sink. I see a couple small screws. Is it in the center here?
Old 11-09-2009, 12:27 AM   #9
Thank you! Very helpful. Now I hope I can get that one off! I just bought this house and it is only one year old. I did not plan to do this but today it started leaking and eventually spraying water out from around the bottom. Ugh!
Old 11-09-2009, 12:41 AM   #10
remove the sprayer hose and you should see the nut holding that horse shoe shaped bracket on.
Old 11-09-2009, 11:37 PM   #11
I can't get it off. Is this supposed to be finger tight, or do I need some kind of tool. I tried to buy one at the hardware store today and the guy there talked me out of it. Ugh!
Old 11-10-2009, 04:09 AM   #12
The hose you use either a basin wrench or small channelocks or whatever you can get on it. the nut that holds the horseshoe looking bracket you will need the right size deep socket or the tool for it from moen. they come with the faucet when you buy it but most people loose it.
Old 11-29-2009, 12:51 PM   #13
I was able to remove that nut with a 5/8 spark plug socket.
cfdavep is offline   Reply With Quote
More On This Topic
Hi I am Mark Williams and on behalf of Expert Village and the producer of this series you can visit our website at www.williamspictures.net. Paper towels are probably best used for maintenance of your faucets. They have a little rougher texture which can... Read More »
Hi I am Mark Williams and on behalf of Expert Village and the producer of this series you can visit our website at www.williamspictures.net. Just kind of go around the whole entire sink cause there are there is soap scum. Soap scum is caused when water... Read More »
Hi I am Mark Williams and on behalf of Expert Village and the producer of this series you can visit our website at www.williamspictures.net. These two are kind of like what we call a handy wipe. They wipe off some of the less stuck on deposits: soap scum... Read More »
Soapscum Removal
Soapscum Removal by Expert Village
Hi I am Mark Williams and on behalf of Expert Village and the producer of this series you can visit our website at www.williamspictures.net. Also the chemicals cause gunk and that gunk builds up as the chemicals evaporate and it is usually up in the... Read More »
Hi I am Mark Williams and on behalf of Expert Village and the producer of this series. You can visit our website at www.williamspictures.net. Storage of chemicals are just important as using them because this what can happen to your trap. Store chemicals... Read More »
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Replaced kitchen faucet - now less hot water? sde Plumbing 5 05-26-2009 04:16 AM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
Low hot water pressure on kitchen faucet KE2KB Plumbing 7 12-19-2008 10:49 AM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 03:02 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
