Trouble Removing An Early Delta 1500 Cartridge - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2012, 04:13 PM   #1
Question
trouble removing an early Delta 1500 cartridge
Having a real problem trying to pull out an early vintage 1500 Delta shower cartridge to replace with a 1700 series. Just updating my polished brass to oil rubbed bronze finish. Yikes what a job!
My question; Is the brass collar just in front of the metal cartridge housing, a threaded collar to twist counter clock-wise? Don't want to break the entire housing back to the plumbing T.
Bruce in Mpls is offline   Reply With Quote
Old 02-17-2012, 04:31 PM   #2
raylo32's Avatar
Rewards Points: 1,240
Not sure of the model numbers but cartridges in many of these old Deltas are almost not replaceable as they are made in 2 parts with the fore part connected to the main body with small delicate copper tubes. If you torque the cartridge it will likely just break these tubes off. I was going to repair my parents' old Delta but luckily I inquired before I put any real torque on it. The plumbers solution to this situation if you don't have an access panel is to cut out a big enough opening around the valve to cut it out and replace the entire thing. Then use an oversize trim ring to cover the opening. Of course if the surround is tile you can remove the tiles, do the replace, then re-tile.
Here is my thread from December:
Repair Delta one handle bath/shwer faucet
raylo32 is offline   Reply With Quote
Trouble removing kitchen faucet rebeccac Plumbing 12 11-29-2009 12:51 PM
Trouble removing ABS P Trap n0c7 Plumbing 12 04-06-2009 06:40 PM
Trouble removing shower wall tiles astroboy Kitchen & Bath Remodeling 2 01-30-2009 10:50 PM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 03:02 PM
Trouble Removing Sliding Glass Doors Drewimus Carpentry 1 11-05-2006 01:43 AM
