Old 04-05-2009, 01:59 PM   #1
Trouble removing ABS P Trap
I've got an ABS P Trap. I cannot get one of the threaded pieces to unscrew by hand and I'm worried that if I use something like a pipe wrench it'll bust. Any tips?
My P Trap looks like this and its the centre piece that won't unturn:
I looked with a flashlight and I don't think someone "accidentally" cemented it.
n0c7 is offline   Reply With Quote
Old 04-05-2009, 02:08 PM   #2
use wrench and be sure to turn it the correct way. If its not glued then it should come right of with a wrench.
plumber Jim is offline   Reply With Quote
Old 04-05-2009, 02:10 PM   #3
Regular crescent wrench or plumbers/pipe wrench?
Old 04-05-2009, 02:26 PM   #4
channel locks or pipe wrench. whatever fits.
Old 04-05-2009, 02:33 PM   #5
BDN
Home Depot doesn't sell ABS anymore. Lowes does. Just thought I'd let you know in case it does break.
johnnydanger is offline   Reply With Quote
Old 04-05-2009, 02:38 PM   #6
That would depend on were you live. They sell ABS here in Colorado.
Old 04-05-2009, 02:40 PM   #7
Oh, what is that trap on anyways? and why are you trying to remove it?
Old 04-05-2009, 02:58 PM   #8
In Canada ABS is used everywhere, easy to find.
It's on a single draining bathroom sink that is clogged up as well as someone dropped a 8" long stick down that I cannot remove without taking the trap off.
Old 04-05-2009, 03:04 PM   #9
BDN
I'm sorry about the mis-informative post. I was repeating what my local Home Depot told me. They had said they stopped stocking it 5 years ago. I thought they stopped as a franchise and not a local thing.
Old 04-05-2009, 03:09 PM   #10
HVAC / Plumbing
If you have no problem getting those materials.. It should be no big deal if it breaks.. It's probably not glued just tight. But , you never know what someone might do
kenmac is offline   Reply With Quote
Old 04-05-2009, 03:11 PM   #11
You could just cut it off and install a trap adaptor then install a trap that you don't glue so you can take it off easier in the future.
Old 04-06-2009, 11:51 AM   #12
I have one of these wrenches http://plumbing.hardwarestore.com/52...ch-198010.aspx
Pretty sure I got it at home depot or lowes and it works great for getting those fittings lose. Alot easier to get in there than a big pipe wrench.
ponch37300 is offline   Reply With Quote
Old 04-06-2009, 06:40 PM   #13
Thanks all. I got it off. The bigger problem was the 4 year old rusted drain pipe that snapped off the flange after I removed the P trap! Can't believe the quality these days. This was my first sink job, I found it to be alot like a garden hose. You fix the leak in one spot, and three others pop up. I torqued everything down, used pipe dope on the threads, and I was getting small leaks from certain spots. I looked at the other drains in the house and they were all siliconed around EVERY possible spot it could leak. I did the same, and problem solved. I don't care much for plumbing as a slight turn here and there or a dab of this can be all it takes to slowly flood your floor and the 24 hour drying period to see if things leak sucks! Practice makes perfect I guess?
Trouble removing shower wall tiles astroboy Kitchen & Bath Remodeling 2 01-30-2009 10:50 PM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 03:02 PM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 08:30 PM
Trouble Removing Sliding Glass Doors Drewimus Carpentry 1 11-05-2006 01:43 AM
