| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Lighting an Oven's Bottom Pilot Light
by Expert Village
Okay, so the next step is to pull out the broiler pan and look into the boiler and in the very back you will see there is the receptacle or the pilot light assembly. You will simply stick a match up to the pilot light and "poof" the pilot light is lit... Read More »
How to Use Tankless Hot Water Heaters
by eHow.com
Using your tankless water heater is as easy as turning on your faucet. Whether you have chosen a gas or electric water heater, using them is the same. Once the tankless water heater is properly installed, you simply turn on the hot water. Read More »
How to Insulate a Water Heater
by eHow.com
This is an easy project that not only benefits the environment, but saves you money on your power bills. Having your water heater properly insulated results is less heat loss. So all the energy is spent on heating the water you will use, not wasted in... Read More »
How to Buy a Space Heater
by eHow.com
A space heater can save money on gas and electric bills because it heats only a small area and efficiently converts almost all of its energy into heat. However, heaters can pose a serious danger from fire and toxic air pollution. Reduce these risks by... Read More »
How to Light a Propane Gas Barbecue Grill
by Expert Village
So we’re back, and we’re going to show you guys how to get your propane gas grill lit safely and efficiently. We’ve already got our propane tank hooked up, so at this point I’m going to go ahead and show you, this is essentially a... Read More »
