Triple Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2008, 07:02 AM   #1
Whatamess
Triple sink drain
Greetings,
Does anyone have a good way to hook up a triple bowl kitchen sink with just one drain line? No 4way cross fittings available here.
Check out the current set up. Yes they are not connected to the drains and no trap. Price of home $465K
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 12-12-2008, 07:41 AM   #2
Pic of the week.
jerryh3 is offline   Reply With Quote
Old 12-12-2008, 04:47 PM   #3
seen a bar sink hooked up similar, you can piece together the piping, plus add a trap in there. The problem I seen was getting the reducers to get from the sink drain basket to the piping, they have to be out there, most likely a commercial plumbing part.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 12-12-2008, 08:43 PM   #4
It is obvious that the trap will need to be installed in the horizontal line going into the wall. I would elbow the center drain over into a vertical tee on one of the other sink drops. All 3 sinks will be handled by the one trap. Without a "cross", you don'thave many choices.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-12-2008, 10:23 PM   #5
skyman's Avatar
I would cut the 1 1/2" coming out of the wall and ninety it over about a foot, 90 it again to come straight out, put the trap on, then 90 it again to keep the tee from being in the way. Or use 45's.
skyman is offline   Reply With Quote
Old 12-12-2008, 10:40 PM   #6
Rewards Points: 2,906
Costa Rica? $465,000?
Are you sure it isn't a Rasta clubhouse in Jamaica?
Roll up a big joint,
twist it on the ends,
take a deep toke,
and pass it to a friend.
We jammin man.
Besides no p-trap, the strainer basket tail pieces are just hanging loose inside the drain piping, there's no clean out to run a snake into (maybe it's out of the frame), and I don't think you can connect ABS to PVC like that (except if you use construction adhesive for the pipe cement, maybe).
Nestor_Kelebay is offline   Reply With Quote
Old 12-13-2008, 06:59 AM   #7
Whatamess
It is all PVC, they have white,gray and green PVC here. No clean outs you see it all. That is 2 1/2" drains run the whole way. On the other sinks they used these mechanical type traps with flex lines to stop up. I have never seen them before.
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 10:17 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
utility sink, washer drain simon Plumbing 4 11-14-2007 08:30 PM
Drain placement for sink simonb Plumbing 3 09-08-2007 02:08 PM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
