Trim Kit Wont Fit After Tiling - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2011, 08:02 AM   #1
Rewards Points: 150
Trim kit wont fit after tiling
I am doing some work on a newly acquired house that was a rental. The shower was recently tiled and now the trim kit wont fit because the walls been bumped out. I tried going to the local plumbing supply house to get a longer stem. Unfortunately the plumbing is from the 50's and obsolete.
Is there some sort of stem extensions I can get? I only need a 1/2 inch. The handle just can grab the stem end when the trims on?
any ideas greatly appreciated since cutting the wall and replacing the mixer seems extreme to make trim fit.
organick is offline   Reply With Quote
Old 06-16-2011, 08:09 AM   #2
Just call me Andrew
Rewards Points: 1,020
pictures would help
Andrew
secutanudu is offline   Reply With Quote
Old 06-16-2011, 08:56 AM   #3
DIY staff
Rewards Points: 7,174
You local plumbing supply shop should have the extensions.
Old 06-16-2011, 08:58 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
How well is the valve secured in the wall? I have been able sometimes to loosen clamps or p-tape enough to get 1/2" of movement out of copper water lines . . . galvanized would be a different story.
is 1/2" where your threads will start? If thats the case you probably need more than that.
Journeyman Plumber
Old 06-16-2011, 02:02 PM   #5
Rewards Points: 150
the local plumbing shop told me they never saw anything like it when I took the stem in. They think its a manufacturer that went under 30 years ago. The stems extend past the tile a good five inches or so.
The thing is the trim kits are based on the mixers being a dimension behind the wall. which I suppose worked before whoever tiled it in without considering that. so now when the trim kit is put on you cant clam the handle on the stem end.
Old 06-16-2011, 03:17 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What's on the other side of that wall in that location? Can you open the other wall for an inspection? Once in there you may be able to relocate the assembly a little and move it outward on the shower side.
XXX
Old 06-16-2011, 05:54 PM   #7
Rewards Points: 150
Have you tried to find a replacement handle where the stem does not inset so deep in the handle
josall is offline   Reply With Quote
Old 06-16-2011, 10:02 PM   #8
Rewards Points: 150
There is just a sheetrock wall on the backside. It is textured though so could be a pain and you look directly at that wall when you walk in the room. Not opposed to doing it if I have to. I just thought maybe you could buy an extension for the stem somehow? Seems like a common issue.
Old 06-17-2011, 09:17 AM   #9
Doing it myself
Alan's Avatar
It is a common issue, and the biggest part of the problem is finding the right parts.
MFG's don't make stem extensions for one style of handle so that other MFG's handles will fit their stems. They all have their own length and number of splines.
If you can't get a generic handle to work, your best bet is to probably replace the valve. If you're worried about the sheetrock you could have someone make a cabinet door that you could mount to the wall there and then you'd have future access to it.
Journeyman Plumber
Old 06-17-2011, 01:00 PM   #10
NACE Coating Inspector
mustangmike3789's Avatar
THATS WHAT SHE SAID
mustangmike3789 is offline   Reply With Quote
Question about removing trim wall in foyer cary00silve Remodeling 1 02-02-2010 12:02 PM
What trim is more water resistant and holds paint better: Miratec or Smart Trim? Studly Building & Construction 4 10-03-2009 07:45 AM
wood trim when tiling counter ponch37300 Flooring 6 04-29-2009 06:47 PM
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 01:19 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 03:19 PM
