Old 11-25-2007, 08:37 PM   #1
Question
trickling water sound in the drain
we had a water system installed last year and in the past few months i have been noticing that in our kitchen drain you can here water draining a trickle sound. i want to know if this is a normal thing ? i know that the brine tank is supposed to drain late at night but i didn't think it was to drain all the time.
any help or advice would be nice. the system is a Hague i am not sure of spelling.
yfulmer is offline   Reply With Quote
Old 11-25-2007, 10:47 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Water trickling noise through the drain system when everything is supposed to be off usually indicates a leaking toilet flapper.
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-25-2007, 11:49 PM   #3
would the toilet not refill?
Water and Drain Line Location Material Tester Plumbing 1 11-27-2007 08:40 PM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 11:22 AM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 08:36 AM
Water sound in Pipes Robb Plumbing 14 12-26-2006 11:48 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
