Triangle Gasket - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2012, 03:28 PM   #1
triangle gasket
How do you take off the old on and install the new one.
P2theG is offline   Reply With Quote
Old 09-21-2012, 03:56 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 806
If you expect a detailed answer you better give a detailed description of what you have...
Old 09-21-2012, 06:35 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Open fingers
Grasp triangle gasket fully
Pull triangle gasket away from the surface it is applied to
Release triangle gasket into garbage
Open fingers
Grasp new triangle gasket fully
Apply new triangle gasket where old triangle gasket was.
Journeyman Plumber
Old 09-21-2012, 07:35 PM   #4
Plumber
Rewards Points: 806
Originally Posted by Alan View Post
Open fingers
Open fingers
They teach you that in school?
Old 09-21-2012, 07:43 PM   #5
Rewards Points: 13,994
I'm still trying to figure out where a trainguler gasket would even be used in plumbing.
Old 09-21-2012, 07:47 PM   #6
I have no idea but googling "plumbing triangular gasket" pulled up this thread here in the #2 search position:
Installing a Kohler triangle gasket.
http://www.plumbingsupply.com/images...sket-51487.jpg
I'm probably way off base but hey, it is a triangular gasket!
allthumbsdiy is offline   Reply With Quote
Old 09-21-2012, 09:56 PM   #7
Rewards Points: 582
I give up.....do tell
Old 09-21-2012, 10:33 PM   #8
Doing it myself
Alan's Avatar
I'm so smart, i didn't even need schooling to figure that one out!
Journeyman Plumber
Thicker Waste Elbow Gasket, Better Seat or Plumber's Putty? D.M.H. Plumbing 2 04-26-2012 11:31 AM
New shower drain installed, but gasket not sealing dryvlyne Plumbing 5 10-23-2011 09:29 PM
Installing a Kohler triangle gasket. liquidvw Plumbing 6 08-01-2011 12:26 PM
Should gasket overlap spud washer on toilet? boarderx Plumbing 19 01-03-2011 11:40 PM
Carrier 58msa burner gasket mdflyer HVAC 12 12-26-2010 01:41 PM
