Trench For Sump Pump In Crawl - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2013, 12:23 PM   #1
Rewards Points: 664
Trench for sump pump in crawl
I have groundwater accumulating in my crawlspace. I have to do the nasty job of trenching out my crawl space along the wall so I can lay pipe and gravel that will lead to a sump pump. How deep do I make this trench and how close to the foundation wall do I make it? Thank you in advance to all who help.
crescere is offline   Reply With Quote
Old 05-14-2013, 12:49 PM   #2
MarginallyQualified
Rewards Points: 2,464
I have to do the nasty job of trenching out my crawl space...
Craigslist Day labor 2 guys
How deep do I make this trench and how close...
How deep is a (math) function of how close.
Right up to it close is usually better/best.
Not more than a foot deep should be enough.
Get a tub for the sump pump note how far below the lip the inlet ports are.
And no, you don't pitch the perf drain pipe.
Old 05-14-2013, 07:14 PM   #3
Rewards Points: 1,770
Make sure you backfill with gravel.
Old 05-14-2013, 10:35 PM   #4
Rewards Points: 664
Really? How wil the water drain toward the sump pit?
Old 05-14-2013, 10:37 PM   #5
Rewards Points: 664
Also, my electric panel is full. I could tap into the electrical going for my washing machine or the circuit that feeds my garbage disposal/ dishwasher. Should that be okay?
Old 05-14-2013, 11:05 PM   #6
All your moving is water. Water will seek its own level and it will naturally go to the lowest point your sump pit.
Old 05-15-2013, 12:58 AM   #7
Rewards Points: 744
Washing machine, dishwasher, and garbage disposal are usually dedicated to those appliances and cannot be shared. It really depends on your local code though.
Seattle2k is offline   Reply With Quote
Crawl Space Questions mark2741 Building & Construction 1 12-24-2011 12:20 AM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 04:56 AM
replaced flooded convertible jet pump, pressure will not go over 30 lb. dcreech Plumbing 4 09-18-2011 11:14 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 08:55 AM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
