Old 10-12-2011, 08:25 PM   #1
Trench Drain
I just installed a trench drain in my backyard which is connected to a solid 4 inch PVC pipe which I am running underground to the front of my house so the water will get out to the street. Should I install a screen at the end of the 4 inch pipe where it is sticking out of the ground? The only reason I ask is if I don't won't critters possibly live in the trench drain system in the summer time? Any help would be much appreciated.
bsmith95610 is offline   Reply With Quote
Old 10-13-2011, 12:18 AM   #2
Persona Non Grata
VIPlumber's Avatar
Trench Drain
If you're worried about animals getting in there then install an swing or spring check valve. It allows flow in only one direction, and closes if there's no flow.
VIPlumber is offline   Reply With Quote
Old 10-13-2011, 11:47 AM   #3
Trench Drain
I can' seem to find a swing or spring check valve when I look on google. I'm looking for one that would attach to a 4 inch PVC pipe. Anyone else have any ideas or can someone provide a link to one that they think would work?
Old 10-14-2011, 12:51 AM   #4
Persona Non Grata
VIPlumber's Avatar
Trench Drain
Really? I did within the first few suggestions. Anyways go down to your local plumbing supply house, not big box, and they'll have what you need.
Old 10-14-2011, 09:39 AM   #5
call me E
TheEplumber's Avatar
Trench Drain
google backwater valve.
Tags
drainage, trench drain
Tying into 50's style clay drain tile perimiter system/exposed Pit / Wall membrane alecmcmahon Plumbing 6 12-29-2010 08:23 AM
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 11:24 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
