Tree Roots - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-10-2011, 10:21 AM   #1
Rewards Points: 790
Tree Roots
About a year or so ago every time we did laundry our main floor drain in the basement backed up. It got worse and worse so we had someone come in and clear the drains. They found tree roots at 90 feet out.
Well, it has happened again. The question I have is, is the city responsible for this issue. 90 feet out is not even close to my property and is well in the city's jurisdiction. Does that matter or is it my problem to solve?
cibula11 is offline   Reply With Quote
Old 08-10-2011, 10:28 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
If public water or sewer connections having problems are on the homeowner's property, it is the homeowner's problem.
If the water or sewer lines having problems are on city property, it is the city's problem.
Call the city.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-10-2011, 10:29 AM   #3
Rewards Points: 1,548
If the problem is in the sewer main running in the street or other public right of way, then the city would be responsible.
If the problem is in the line (sewer lateral) leaving your house, including portions passing through other people's property via easement, then you are responsible.
In most cases the portion of the lateral under the sidewalk and street up to the main is your responsibility.
Old 08-10-2011, 11:49 AM   #4
Rewards Points: 790
So, you are saying it would be worth asking the city? How do I prove it is not my issue? Call them first or have someone come and out and remove them and then call the city?
Old 08-10-2011, 03:24 PM   #5
How far are you from the street?
Can you get any old plans from the city showing the locations of sewer hookups? (Occasionally a sewer hookup is to the back instead of to the street)
Would you want to get a drain video contractor in to view the inside of the sewer line, this can make a very educated guess about whether the roots are in your line or in the main because the main is bigger and the video camera can show that.
Impact on this tree of roots cut to install foundation? WillK Landscaping & Lawn Care 12 04-12-2011 07:37 AM
Water Shut Off Valve and Tree Roots norulez43 Plumbing 3 11-17-2010 11:30 AM
removing tree roots from sewer tile 4just1don Plumbing 4 09-10-2010 07:23 PM
Cutting Magnolia tree roots jensu2 Gardening Forum 1 07-15-2010 01:41 AM
Tree roots in Sewer mikehende Plumbing 7 03-25-2008 05:21 AM
