Old 10-06-2008, 06:07 PM   #1
traps & vents
I'm "helping" a friend convert a garage into a master bath with shower stall, garden tub, sink and toilet. On the other side of an ajoining wall will be the laundry room. I need to know: which items need to be vented independantly, and do I install traps for each item (except toilet, which has it's own)? I'm using 3" dwv because the old lines were 3" castiron. The shower, sink and washing machine drop directly into the main drain; the toilet and garden tub are "t" ed.
Stan the Man is offline   Reply With Quote
Old 10-06-2008, 07:54 PM   #2
traps & vents
Traps for everything. One for safety and the other for smell. Sewers have lots of methane coming out of there.
Marvin Gardens is offline   Reply With Quote
Old 10-06-2008, 08:32 PM   #3
traps & vents
You need traps on all of the fixtures. The toilet will drain into the main 3" line. The sink and garden tub need a 1-1/2" drain and the shower requires a 2" drain. I have included a link with "typical" drain and vent diagrams.
http://www.hometips.com/hyhw/plumbing/74drain.html
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 10-06-2008, 11:36 PM   #4
Week End Warrior
Frank Steele's Avatar
traps & vents
Frank Steele is offline   Reply With Quote
Soffit Vents Sammy Building & Construction 9 07-07-2008 07:31 PM
ridge/soffit vents not enough?? cbice74 Roofing/Siding 1 06-16-2008 06:02 PM
p traps and vents TEEBOW Plumbing 9 04-14-2008 08:09 PM
sofit vents + gable end vents no ridge vent mattg1970 Roofing/Siding 5 10-18-2007 10:47 AM
How many heating vents needed per room? AllGoNoShow HVAC 4 01-23-2007 05:06 PM
