Trap Primer Stuck Open - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-22-2010, 05:53 PM   #1
Trap primer stuck open
After our neighborhood water was shut off and turned back on my trap primer is running constantly. I assume there's debris in it. Can the valve be cleaned? It's on the house side of the main house shut off valve, of course, and is in the line to feed a drain that accepts the AC condensation drain and the t & p relief line from the hot water heater.
Beepa is offline   Reply With Quote
Old 07-23-2010, 10:43 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Shut the main water line off, and dismantle the trap primer.
Turn the water pressure back on briefly to flush out the debris, and then turn it off again.
Reassemble the primer.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Used primer without stirring and now concerned pstoll Painting 1 07-21-2010 11:06 PM
peeled primer (left the blue tape on too long) tjmack Painting 2 02-25-2010 01:16 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 11:10 AM
Primer vs. Flat paint lovetrading Painting 3 08-22-2008 09:13 PM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 08:30 PM
