Trap Primer Curiousity Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-01-2012, 09:44 PM   #1
Rewards Points: 240
Trap primer curiousity question
I've noticed something I can't figure out about the plumbing in the restrooms at work. The lavs in these restooms have some type of electronic faucet; there's a sensor near the lav and apparently a solenoid operated valve in the adjacent mechanical room (no valve is visible underneath the lav). There are two such lavs in most of the restrooms; a few have four. Each restrooms also has a floor drain.
In every restroom that I've checked so far, there is a trap primer for the floor drain that is tied into the rightmost lav. After that lav is used, about 15 seconds later, you can hear water run into the floor drain for a few seconds. Straightforward so far. However, the lav itself also has a trap primer, which runs for a few seconds after the floor drain trap primer. Only the rightmost lav has this trap primer. Why would a lav, especially one in a large office building's restroom that is used frequently, need a trap primer? And why is only one lav in each restroom so equipped?
fa_f3_20 is offline   Reply With Quote
Old 03-01-2012, 10:06 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Question
What type of trap primers are they?
The ones we use are operated off of pressure drop in the entire system. Using one fixture exclusively to set off the primer would not really be an acceptable means of priming the trap.
The way you are describing it really makes no sense. The solenoid for sensor faucets that i've seen are usually internal, but depends on the make. Some are very different. I'm not even sure what the solenoid has to do with the trap primers anyway.
Are you sure that there's a trap primer on the lav trap? Maybe it's a condensate inlet or something? Can you actually see the trap primer devices?
This post is so confusing.
Journeyman Plumber
Old 03-01-2012, 10:08 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 674
I have hooked HVAC drains to lav tailpieces. Could that be what you saw?
I did plumb a residence hall at a college once. All showers and lavs had primers because the building was empty during the summer
first coat of primer is on the drywall, but it's not pretty wengang1 Painting 14 12-25-2013 06:16 PM
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 07:47 AM
Bathroom Trap Question... Mozart Plumbing 4 07-19-2011 06:25 PM
primer question hegster Painting 1 11-22-2010 02:24 PM
Self-stick vinyl tile primer question. Jim F Flooring 5 11-12-2010 07:28 PM
