Old 05-21-2012, 02:00 PM   #1
Trap leaking
I replaced the faucets in the bathroom but it is now leaking from the trap. I replaced the washer so I am thinking it must be the packing nut but I can not get the pipe loose that comes out of the wall to replace the nut. I tried to spray wd40 on it but it won't even budge. Does anybody have any suggestions?
s_fields is offline   Reply With Quote
Old 05-22-2012, 02:42 AM   #2
Trap leaking
The pipe coming out of the wall is soldered in. You could cut it off 3" from the wall and install a 1- 1/4" coupling that has a nut and rubber ring on each side of it. Then install a new p-trap into it.
sanec1 is offline   Reply With Quote
Old 05-22-2012, 05:26 AM   #3
Ravenworks's Avatar
Trap leaking
Sure looks like a Desanco to me and the fitting is brass with a nut on it like you see in the picture.
Try tapping on it with a hammer and use a pair of big channel locks to loosen.
U.S.M.C. "80-84" E.O.D. 1369
Ravenworks is offline   Reply With Quote
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 08:59 PM
Leaking Connection Between PVC drain and Cast Iron Trap sleepyjen Plumbing 1 11-14-2011 11:43 AM
P Trap Leaking ws450r Plumbing 0 07-18-2011 09:01 AM
Leaking Trap Connection bklusa1 Plumbing 3 02-17-2011 10:50 AM
Leaking Condenation Trap - Bryant falcon HVAC 9 04-01-2009 07:17 PM
