-   -   Trap leaking (http://www.diychatroom.com/f7/trap-leaking-144439/)
s_fields 05-21-2012 01:00 PM
Trap leaking
1 Attachment(s)
I replaced the faucets in the bathroom but it is now leaking from the trap. I replaced the washer so I am thinking it must be the packing nut but I can not get the pipe loose that comes out of the wall to replace the nut. I tried to spray wd40 on it but it won't even budge. Does anybody have any suggestions?
sanec1 05-22-2012 01:42 AM
The pipe coming out of the wall is soldered in. You could cut it off 3" from the wall and install a 1- 1/4" coupling that has a nut and rubber ring on each side of it. Then install a new p-trap into it.
Ravenworks 05-22-2012 04:26 AM
Sure looks like a Desanco to me and the fitting is brass with a nut on it like you see in the picture.
Try tapping on it with a hammer and use a pair of big channel locks to loosen.
