Trap Adapter Leak? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-26-2010, 02:03 AM   #1
Rewards Points: 552
Trap Adapter Leak?
HELP!
I'm having trouble with a trap adapter that's leaking. The adapter is made by the Charlotte Pipe and Foundry Company and is comprised of two pieces, a PVC adapter and a combination nut/washer. Here is a diagram of the actual part: http://www.charlottepipe.com/Product...?product=03223
Unfortunately, the sink has a slight angle in it, which forced me to angle everything accordingly so it lines up. I've checked everything, but I can't understand why the adapter is leaking. The pipe threads are fine and I've tightened the washer. See photo 2 for a shot of the leak. What am I missing?
Thanks,
Kelly
kcrossley2 is offline   Reply With Quote
Old 01-26-2010, 06:51 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 330
Ayuh,... It's a compression fitting,.. It won't seal unless it's sitting Straight on the piping...
It looks like it's too short coming from the wall..
Old 01-26-2010, 08:06 AM   #3
That leak is coming from above somewhere. Most likely where the scratch-thread tailpiece screws into the pop-up assembly, OR (even more likely) where the rubber gasket compresses against the bottom of the bowl. I usually spread some pipe dope on top of that gasket and also on the threads before I tighten the nut.
Ishmael is offline   Reply With Quote
Old 01-26-2010, 11:15 AM   #4
Rewards Points: 552
Nope, the leak is definitely coming from the trap adapter compression gasket. Last night, I wrapped some teflon tape around the trap adapter threads and that seems to be working, for now. Not sure why. BTW, it only leaks when there is water standing in the P-trap assembly.
Bondo, are you saying the trap adapter is too short? If so, how high should it be?
Thanks,
Kelly
Old 01-26-2010, 01:56 PM   #5
Household Handyman
Rewards Points: 1,408
Errr, you did put the sealing ring at the top of the adapter, and in the correct position, didn't you? David
Old 01-26-2010, 02:47 PM   #6
Rewards Points: 552
The sealing ring is built into the top. It only fits one way.
Old 01-27-2010, 01:55 AM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
ive never seen it done quite like that ,but i guess it fits. is beveled washer pointing down? is it an 1 1/4" reducing washer? try teflon tape around washer itsel before installing nut maybe.
plummen is offline   Reply With Quote
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 12:46 PM
1 and 1/2" trap adapter for 2" drain pipe maxfischersweet Plumbing 5 11-19-2009 11:33 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
P Trap leak industries Plumbing 2 07-24-2009 04:45 AM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 11:10 AM
