Trap Adapter - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-07-2011, 04:47 PM   #1
trap adapter
what is a trap adapter
kyleraup is offline   Reply With Quote
Old 11-07-2011, 09:13 PM   #2
Plumb or Die!
This is the fitting that connects the fixture outlet pipe of your sink to the PVC or ABS that comes out of the p-trap. It's a transition fitting that is a compression style on the sink side, and glued on the other end.
plumber666 is offline   Reply With Quote
Old 11-08-2011, 09:10 AM   #3
Rewards Points: 150
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
josall is offline   Reply With Quote
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
Brass p trap and ABS wall drain nitting Plumbing 4 04-21-2011 09:06 PM
Trap Adapter Leak? kcrossley2 Plumbing 6 01-27-2010 12:55 AM
1 and 1/2" trap adapter for 2" drain pipe maxfischersweet Plumbing 5 11-19-2009 10:33 PM
