Old 04-28-2012, 11:35 AM   #1
transfer valves
trying (unsuccessfully) to find a 3 way transfer valve with 3/4" inlet and for one outlet, the other outlet could be 1/2" or whatever. As an extra problem, the valve must have at least 1 !/2" mounting threads.
Using this on a whirlpool tub already plumed with 3/4" copper as is the house.
Will cut into line (with temp already set) to faucet that I am unable to get to as it is on the other side of the tub.
thanks
ken in WV
kenatofc is offline   Reply With Quote
Old 04-28-2012, 12:54 PM   #2
transfer valves
May want to try giving this place a call.
http://www.plumbersurplus.com/Cat/Sh...lves/1197/List
Old 04-28-2012, 02:17 PM   #3
transfer valves
turn supplies into 1/2 to go to 3 way diverter that is if you are going to use it for shower heads since they all are regulated at 1.5 g.p.m. 1/2 line is more then enough
onstructionmanuals.tpub.com/14259/css/14259_50.htm
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 05-02-2012, 08:20 AM   #4
transfer valves
To Joe and Jay.
Thanks for the responses. Plumbers Surplus does not have this. Was trying to use the 3/4" outlet for filling a Jacuzzi tub faucet and do not wish to reduce the flow to the faucet by reducing the size of the line.
May have to rethink and go with two 1/2" inch outlet into the 3/4" line and switch to a 3 outlet transfer valve !!
Ken in WV
Old 05-02-2012, 10:11 AM   #5
Doing it myself
Alan's Avatar
transfer valves
What's wrong with just getting a 3/4" transfer valve and reducing the line for the shower down to 1/2"
Nevermind, I read it 2 more times and it made sense.
I don't think you're going to find one. There's a reason the inlet is sized larger than the outlets, so that if you want to use both at once, the flow rate will keep up.
Journeyman Plumber
Old 05-02-2012, 08:31 PM   #6
transfer valves
ok so why not use 3/4 tub diverter with a t that then reduces to 1/2 to got to shower diverter or shower head.
other option just t off of 3/4 supplies leave tub fill faucet in place "that is if it is a true 3/4 tub valve" and then put a shower valve above it for shower. i have seen this often in houses built in the 70's to control valves one for tub down low and one for shower around 48 " high
Choosing a manual transfer swtich for 7500 w generator homerb Electrical 11 07-24-2012 01:15 AM
Generator Transfer Switch Trouble wgramer Electrical 23 11-12-2011 08:23 PM
Custom wiring a generator to a transfer switch robojoe_fl Electrical 4 06-08-2011 01:36 AM
Stop valves in bathroom while drywalling StevePax Plumbing 11 01-17-2010 06:52 PM
Generator with 2 transfer switches? Isaac-1 Electrical 4 03-16-2009 08:45 PM
