Town Water Supply Line Code. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-10-2011, 06:36 AM   #1
Town water supply line code.
Can anyone tell me the code for running a town water supply line through the foundation? My home has a 1" black PVC type pipe coming through the concrete that connects to the meter via nut and ferrule. My question is, shouldn't there be a sleeve and seal around the pipe? Won't the PVC break down from contact with foundation or break from foundation settlement? The street was converted to town water/sewer a few years ago, before I purchased the property. I had ground water come in between the pipe and foundation and had to excavate the front yard to relieve pressure so I could use hydraulic cement on both sides of the foundation. Thank you...
Sorry Massachusetts
ds211 is offline   Reply With Quote
Old 03-10-2011, 07:18 AM   #2
DIY staff
Rewards Points: 7,174
You will get a far more accurate answer if you put you location into your profile.
Codes vary a lot---we have members from the U.S--Canada,England, Germany,and New Zeland to mention just a few.----Location helps with codes.
Old 03-10-2011, 07:49 AM   #3
Learning by Doing
Leah Frances's Avatar
Your town is the best entity to answer this question. Good luck.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-10-2011, 10:32 AM   #4
Rewards Points: 3,130
I believe code in most places (USA anyway) requires sleeves for foundation penetrations (water and sewer). Usually one pipe size larger than the water or sewer line. Even if it didn't I'd do it anyway just to be safe.
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Gray PCV for water supply line - is this OK? Jim S. Plumbing 13 08-09-2010 09:20 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 05:07 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
