Towing Camper Over Septic Fields? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2012, 08:17 PM   #1
Rewards Points: 310
Towing camper over septic fields?
Hey all...
I have a 1300 pound pop up camper. I have a 425 pound riding mower. If i wanted to move the camper around, think its safe to tow it over the septic fields? I have in ground sprinkler too.
denemante is offline   Reply With Quote
Old 12-02-2012, 08:43 PM   #2
Civil Engineer
Rewards Points: 4,944
Septic field pipes (NOT the tank, the fields) are typically at least 14-18 inches below grade. It is generally OK to run a light truck over them. Consider how they are built, first the field is excavated to grade, then the pipes are installed and covered with gravel, finally the soil cover is put on. This is all done using heavy equipment. The tank itself is usually reinforced concrete, and rated H-10 or H-20, depending on the manufacturer. An H-10 or H-20 rated tank can support a pickup truck easily. Of course, you may have an old tank that is not rated, so best to check your plans before driving on top of the tank.
Old 12-02-2012, 11:04 PM   #3
Rewards Points: 310
Great info. The home was built in 1998. Do you think there would be anything old-school about the field, or would that age weaken it at all? I sense that I'd be fine towing this camper across that area...but just want to be sure. I won't be going anywhere near the tank.
good working septic fields flooded more easily? denemante Plumbing 11 01-10-2012 02:34 PM
septic emergency? help! denemante Plumbing 47 11-21-2011 01:05 PM
Septic problem or vent problem? wilsonstark Plumbing 9 01-17-2011 06:35 PM
septic tank problems. littles Plumbing 1 02-24-2010 09:30 PM
Septic Newbie Needs Advice flyboy Plumbing 5 04-06-2009 06:05 PM
