TOTO Toilet 2 Stage Flush? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-02-2013, 10:05 PM   #1
MikeKy55's Avatar
Rewards Points: 254
TOTO toilet 2 stage flush?
I have a house that was built in 2002. The two baths have TOTO brand toilets. They are 1.6 gal? I think? Anyway ever since I moved here, I always found it necessary to flush them twice (if anything other than taking a leak was in order). Well, the other day I wasn't sure one flushed so I pushed the handle down and held it for a minute. It was like a gully washer! I lifted the tank top off and flush it like always and noticed it stopped flushing after half the tank of water went in the bowl. If I hold the lever down longer, the entire tank full goes in and is much more effective. Is that the way these are designed? Thanks in advance.
'It's never too late to say ''THANK YOU'' to a veteran of our armed services'
MikeKy55 is offline   Reply With Quote
Old 04-02-2013, 10:09 PM   #2
Rewards Points: 13,994
Sure sounds like a duel flush toilet.
One for #1, a longer one for #2.
MikeKy55 (04-02-2013)
Old 04-02-2013, 10:11 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 806
Yup, I bet the instructions are on a plastic label on the bottom side of the lid
Old 04-02-2013, 10:12 PM   #4
MikeKy55's Avatar
Rewards Points: 254
Hummm... I will look. Thanks!
Old 04-03-2013, 03:09 AM   #5
Rewards Points: 1,016
I have ToTo toilets. Yes, two stage. Quick bump for liquids only, hold a bit longer for solids.
____________
Vince
Toilet - Slow Flush Irishman Sean Plumbing 6 03-24-2013 07:40 PM
Toilet Won't completely flush kmkiley Plumbing 6 07-14-2011 07:05 AM
Toilet & double flush Richo Plumbing 0 07-26-2010 03:03 PM
Toilet won't flush hollywood60640 Plumbing 6 12-05-2009 08:33 AM
New Toilet Does Not Flush klugej Plumbing 3 04-30-2007 10:51 AM
